I try to rip audio wrom DVD with Vob2Audio, BUT...
I could set up vob list file and target file, but
audiostream I could not. I try to click on everything,
but no effect. Can somebody help with easy instruction, how vob2audio works? Or maybe somebody can advice with another program to get audio from DVD?
Thank you, Evgen.
E,
I have not had much experience using vob2audio. However, i use dvd2avi and am able to extract the wave from the movie. You could even extract just a snippet by using markin\out. Hope this helps!
Regards,
The Daywalker -
i am having the same problem with the vob2audio program and could never get it to work. i tried different things but the audiostream never came up therefore i just kept using dvd2avi and never had a problem.
still i wonder why the vob2audio did not work? hmmm...
-Keith-
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
