Hi, There! I'm a newbie (to this site & to ripping) so any help would be greatly appreciated...
I'm using the programs: Smart Ripper & FlaskMPEG to create AVI files from the ripped DVD.
However I have this problem in stages of action or camera movement (when encoding the AVI file, that is, in FlaskMPEG - the initial ripping of the VOB & IFO files in SmartRipper is fine): Lines appear that sorta put parts of the image out of line.
Can anybody help me fix this problem?
THANK YOU in advance!
BTW, you have to right-click on the image, select Properties and highlight the URL of the image & paste that into your browser for it to work.
I don't know of any Image Hoster that allows outside linking so if anyone knows of one, I'd really appreciate that too!![]()
I used to have that same problem when i first started. One thing that is best is not to preview the movie while your encoding it so deselect display output or video. also when your choosing how to encode go to post processing under flask mpeg options and choose HQ Bicubic Filtering. It may be the slowest choice but it gives you the best quality. Thats all i did to fix the line problem for me so i hope it works for you.
-Bizkit54237
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 05:50 -
Ripping a DVD
By andreltr in forum Newbie / General discussionsReplies: 1Last Post: 17th May 2009, 10:29 -
DVD Ripping help
By nsx-r in forum DVD RippingReplies: 3Last Post: 30th Apr 2009, 20:56 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 10:22 -
DVD Decrypter / DVD Fab - Extremely slow ripping speeds in Vista
By awp in forum DVD RippingReplies: 5Last Post: 19th Dec 2007, 14:11
