Results 1 to 24 of 24
  1. I have this soft, DVD2DVDR
    It's very easy to work (only Win XP) but at the end i have several files
    *.avs, *.lst, *.idx, *.sub, *.vob *.vaf and more.
    Now... i need to find the correct files to burn...
    If anyone know's to work with this soft, please give-me some help.
    There's no guide for this.
    Tks
    Best Regards
    J oao
  2. Can you let me know where you got this software or where to download it?
    Nero can burn VOB files to disk but you must have a folder similar to what you would find on a commercial DVD.
    Cheers
    Myth.
  3. Hello.
    You can download this soft and updates here
    http://134.102.55.6/cgi-bin/download/dtrack.cgi?rc=dvd
    This soft looks like DVD2SVCD, but...
    Let's try it...
    Best Regards
    Joao
  4. Look's like nobody wants to try this soft
    But for the ones that try...
    At the end of de prog you have a SCP file
    Use Scenarist NT 2.0, 2.5 or 2.6. Import the SCENARIST_SCRIPT.SCP File in
    Scenarist NT and press the Button BUILD. All is done. Now you can burn with
    Scenarist NT 2.6 or any other Burnproggie.
    I have already meda everything but the scenarist prog.
    I don't have it......
    Best regards
    Joao
  5. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Hrm. I get like an error just opening this software... strange... and its such a good idea if it works. I assume it converts down and everything? Let us know how the disk turn out if ya get it to burn.
  6. Runtime error as well, but it looks like a script combo of SmartRipper, DVD2AVI, AVISynth, and MPEG2DEC. I'd rather trust my own settings personally.
    mmm....unexplained bacon...
    Our extended forecast calls for flurries of passion followed by extended periods of gettin it on.
    -Homer
  7. I also get runtime error 13....before it even starts. (in XP).
    I have been waiting for a long time for someone to make a single program that does the lot, this doesnt look like it anyways but more of a "patch" of a lot of other programs. Oh well...
    Blackout
  8. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    maybe someone can traslate the instructions?
    As a lazy man I like the idea of a script to do things for me...
  9. Hi
    I'm stuck with Scenarist... I have the V2.6 but not the serial lnumber.
    Every time i try to open the prog wask for the serial....
    I'm gonna try to find ít... also i'm translating the infos about dvd2dvdr.
    8)
    Best Regatds
    Joao
  10. Very interesting program..but...I suggest an option to skip the ripping process.... if you have an already ripped movie in the hard disk..how can you use this soft?
    However I have an error message too.....
    Grendizer..... GO!
  11. Member tumbar's Avatar
    I have not used this program, however my comment is related.
    I have been using dvd2svcd to do the dirty work. Problem is time factor. Takes about 24-36 hours.
    At the end I end up with a pull down mpv file and an ac3 file.
    Rename to same. Open spruce and follow through. Burn with Nero.
    Got the settings from a guy on doom9.net, in their dvd2svcd forum, guys name is fletch. uses cce. look for his post, he outlines settings. One caution, he says 4600 for dvd size is safe, Ive found better to go with 4450, it's a real pisser to be so close and then to have to go through everthything again.
    Jim
  12. I've found a beta .07 on the net...I think we need some other proggy installed....but which one? ok for smartripper and cce....but the others?
    Grendizer..... GO!
  13. I Did'itttttt....
    I made a DVDR 5*****.....
    Great quailty, DVD quality
    After I run the dvd2dvdr prog and save all files, with Scenarist V2.6 i chose built and after that i have a folder named C.\DVD.
    Just burned with Nero and..... it's done...
    I did all this under Win2000NT pro.
    No crashs... no probs... just don't touch the keyboard....
    Best Regards
    Joao
  14. Looks like it can be a fast process by using AVISynt frameserving to CCE version 2.5. Want to use this process but get runtime error as with people above.
    Aug 2002
    Hawaii
    Hi fellas,
    Where can we find the Scenarist software?
    Thanks a bunch
  16. Set Regional setting in the control panel to German and the program will run.
  17. I did it too ...but.... 1.1gb for a dts audio track is not too much?
    the medium bitrate of the movie is 3800 ...i think is not much....I look the
    .m2v file with poewrdvd and...I don't like it very much....
    I'm looking for scenarist....as soon as possible I will give you an opinion after I will record the dvd-r
    8)
    Grendizer..... GO!
  18. I found the Scenarist V2.6 with Grokster or WinMX ou Kazaa... it's the same thing...
    it's size... 13,4Mb...
    Hard to send by mail...
    I can give you the serial for V2.6... just ask me.
    If you try to do it with CCE.... you lose quality... lot's
  19. have you got new info about this interesting program? a version that could work with an already ripped dvd?
    Grendizer..... GO!
  20. Member marvel2020's Avatar
    Mar 2001
    Vorlon Home World
    FOR EVERYONE USING THIS SOFTWARE THATS GETTING A RUNTIME ERROR 13, CHANGE YOUR REGION SETTINGS TO GERMAN THATS SHOULD CLEAR THAT PROBLEM UP AND ALL THE SETTINGS ARE IN ENGLISH.
    Good luck in getting it to go, i still had problems with it, when i tried to to a conversion. IT came up with some error in GERMAN .
    Looks like it will work for some and not for others.
    Jul 2002
    BATON ROUGE, LA - U.S.A.
    sounds like a trojan
    Where I walk, I walk alone. Where I fight, I fight alone.
  22. Hi.
    I use Scenarist NT 2.6. and import the SCENARIST_SCRIPT.SCP File to make the folders for burning and now i get some errors... it starts the prog importing the files .... but gives 3 or 4 errors and crahs down.....
    I don't know wat's wrong.....??????
    The first time did ok.....
    This prog it's hard to work...
  23. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    crap it needs an older verison of CCE then mine... is there a way to get OLD versions?
    Oh yeah, and what exactly do you do when you open in in Senarist?
  24. Member
    Austria
    I have testet many encoders, and must say the cce gives me overal the superior quality.
    it´s one of the best mpeg2 encoder ever build yet.
    use multipass encoding, and variable bitrates, max 9000kb/s ,avbr 5000 kb/s and min 1000 kb/s.
    And you dont see any differenc, on a TV
    IfoEdit does not work with cce because of the gop sequenc what the cce encoder makes. hope this will be fixed soon
    or the re-mpeg encoder is also very good and free
    AMD XP2000,ASUSA7V333.GF3 V8200 TI200,
    Alpha 8045,Y.S Tec Poer Fan, Seagate Baracuda IV
