Hi, i just bought a pioneer a04 drive. havent installed it yet, but reading up about the region settings, it says it will allow me to change region settings 5 times before it locks... is there any way to change that? i know with some dvdroms you could flash the bios.
i dont intend to use this drive to actually play dvds but only to burn them. how will region settings affect that. like if i put one of my region 1 or region 4 dvds onto my pc and burn it to dvd will it keep its region setting, and will the burner need to be set to the same region setting??
please forgive any ignorance, im an utter n00b when it comes to dvd-r stuff.. no idea at all
Pioneer DOES NOT burn anything other than files to general use DVD-R.
The region setting isn't recorded, nor is macrovision, nor is CSS.
Any DVD-R will be region free and non macro and non CSS.
However, if you want the drive to play back region encoded movies, then the correct region must be enabled in the drive.
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 17:12 -
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 10:26 -
Obama bought the President of England a bunch of DVD that are region 1 LOL
By vatkat234 in forum Off topicReplies: 4Last Post: 20th Mar 2009, 20:15 -
Yamaha DVD w/HDMI remote hack? Region 1 to all region [PAL]?
By eurocd in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jul 2007, 13:58 -
How to Make a Pioneer DVR-520H Region 1 a Region Free player?
By Ossocao in forum DVD & Blu-ray RecordersReplies: 3Last Post: 26th May 2007, 22:35
