Has anyone created a registry editor similar to stinky's for the ATI MMC7.X series that adjusts audio bitrate as well as video bitrate OR does anyone know where these settings might be in the registry so that I can change them manually. Currently the ATI MMC prog lets you record at 44.1Khz (or 48kHz) depending on your version but as far as I know you can't adjust the bitrate. Any help would be greatly appreciated![]()
Results 1 to 1 of 1
Problem with my mixer! I need some assist from a guru!
By hellfire45 in forum AudioReplies: 8Last Post: 17th Jan 2011, 02:54 -
Pleading for guru advice DVD recorder w/digital tuner, hdmi
By arlene in forum DVD & Blu-ray PlayersReplies: 3Last Post: 3rd Nov 2009, 10:55 -
Need an Adobe Encore DVD Guru for this one....
By sdsumike619 in forum Authoring (DVD)Replies: 2Last Post: 9th May 2008, 19:24 -
It was a stinky situation...
By zzyzzx in forum Off topicReplies: 3Last Post: 18th Jan 2008, 14:27 -
simple request to video guru...or is it?
By wormdog88 in forum EditingReplies: 4Last Post: 12th May 2007, 00:57
