Results 1 to 11 of 11
  1. i'm trying to reencode a VOB file with ReMPEG but at the time of start, it just say "Transcoding Susceful" , but the reencoding process , never starts.
    What's happening ?
    i'm trying to copy a dvd of 4.8GB , and i have to reduce it only 100MB.
    i don't know how can i quit some unecesary material without destroying the chapters structure.
  2. Member wulf109's Avatar
    Jul 2002
    Did you create a cfl file for your vob's? You need to shed 400MB,the actual capacity of a DVD-R is really 4.37GB.
  3. Make sure that you open the .ifo file of the main movie vob's (i.e. VTS_01_0.IFO) in IFOEDIT and then under the Tools menu choice select "Create ReMPEG2 cffl". This will create the file that ReMPEG2 needs to start the 1st part of the transcoding.
    Start ReMPEG2 and open the .cffl file that you just created. This will create a new file .vinf that ReMPEG2 needs to do the transcoding. After this file has been created, the "Encode" button should be available. Set your Options correctly and start the transcoding.
  4. my god--- can you talk more slow ?
    my english is not to good.
  5. Originally Posted by LordVader
    It's typed, read it as slow as you want...
  6. Same history........
    Transcoding succeful , and it's not re-encoding anything
  7. What are the contents of the .cffl file that you are using? How big (file size) is the .vinf file that was created by rempeg2?
  8. MAN , listen to me .
    take any DVD with and rip the MENU VOB file.
    try to reencode it.
    if you do it , let me know
    thanx
    the file i'm using is VTS_02_0.VOB
    from the DVD - Britney Spears ( live & more )
  9. To use rempeg2 for VTS_02_0.VOB, here are the basic steps:
    1). Open VTS_02_0.IFO in IFOEDIT
    2). Click "Tools" at the top menu
    3). Click "Create ReMPEG2 cffl"
    4). Leave the file name as "ReMpeg.cffl" and in the default directory
    5). Close IFOEDIT
    6). Start ReMPEG2
    7). Click "Open" button and find the "ReMpeg.cffl" you created
    8). Wait for ReMPEG2 to finish creating the "ReMpeg.cffl.vinf" file
    9). Click "Options" tab at the top
    10). Set "Options" (scale factor, output resolution, frame mode, etc)
    11). Click "Main" tab at the top
    12). Click the "Encode" button
    13). Save file (remember file name and location)
    14). Wait 5-50 hours for movie to finish encoding (depends on speed of computer)
    15). Close ReMPEG2
    16). Open VTS_02_0.IFO in IFOEDIT
    17). Click "VOB Extras"
    18). Check "Re-Mux" option and any others that apply
    19). Enter the "*.m2v file for Re-Mux" from Step 13
    20). Click OK
    21). Enjoy your newly transcoded VOB
    22). Be nice to peope trying to help you
    For more information and pictures, check out this:
    http://mpucoder.kewlhair.com/derrow/rempeg.html
  10. Your English is bad, but your manners are worse.
