just wondering..
Compliant VCD is CBR, 1150kbps, so an hour or black screen and an hour of action scene, it's all the same file size. SVCD (if VBR) will vary a bit.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
VCD's only support hard encoded subs, basically the subs are physically a part of the picture so it doesnt take up any additional space on the disk.
The same applies to SVCD's if you use hard encoded subs as well. But SVCDS also support up to 4 soft encoded subtitle streams. The size that each stream takes up on the disk depends on how many individual subtitles there are in the stream. You can use FitCD to calculate how much space your sub streams will take up.
Soft encoded subtitles hardly take up any room at all. With four streams it adds 2, maybe 3 MB's onto the mpg's filesize.
One thing that you need to pay attention to is your max bitrate because the subtitles are included in this. I'm not sure exactly how much bitrate these add but I have read its around 500kbits, though that seems high to me. The total max bitrate allowed in the SVCD standard is 2778kbits, and that includes Video, Audio, Subs, and multiplexing overhead, so always take this into account when making SVCDS.
Once I put an MKV thru multiAVCHD the subtitles are lost
By mahogany in forum SubtitleReplies: 4Last Post: 8th Oct 2011, 14:49 -
how to put subtitles under the vedio !
By ary190ary in forum SubtitleReplies: 4Last Post: 31st May 2010, 17:48 -
How to put subtitles in a m2ts file ?
By sn0wer in forum MacReplies: 4Last Post: 18th Mar 2010, 10:52 -
How do I get subtitles from a DVD to put into an XVid?
By Emanef in forum SubtitleReplies: 7Last Post: 23rd Jul 2008, 12:45 -
How to put subtitles to a mkv file
By donpato in forum SubtitleReplies: 2Last Post: 6th Apr 2008, 16:17
