  1. I followed Pinoys2210 DVD ripping guide v 2.3...
    But...
    When all was said and done the picture was quite blocky? Its was very good quality but when there was any movement what so ever the picture went blocky and almost blurry?? Is it my bitrate?? I loaded pinoys2210 vcd template for TMPGEnc and didn't change any of his settings is there something else that could be the problem??
    Also i noticed when it was converting, the audio was set on 48000 KHZ isnt it suppose to be 44100KHZ for a VCD?
    Thanks in advance
    Crow
  2. Member MaDmiZe's Avatar
    May 2002
    City of...Atlanta
    If you want to see settings for standard VCD .....in TMPG hit LOAD and select the VideoCD(NTSC) template...or the (pal)
  3. After i finish all the steps in pinoys2210 is it possible to burn on a dvd-r with a cd writer?
