I added subtitles with Virtualdub and frameserved it to TEMPG. The problem is it's out of synchThe subtitles appear a few seconds too early
I've tried to search for an awnser, but couldn't find anything useful.
Can someone help me with this?
I used this program first to convert the subtitles; SRTtoSSA. Then I added the filter in VirtualDub called subtitler.
Didn't change anything -
Since your subtitles are now .ssa, why not load them into Sub Station Alpha, select all the subtitles, select Timing-->Shift times, then input the amount of time your subtitles are off? Then save, load them back into VDub's subtitling filter, and go from there?
Hello. -
You might want to try subsync. When playing the movie in this prog, you can determine at what timing the first sentence begins. You take that time and then open sub station alpha. Now you choose insert script. A small window will popup. You select adjust timings and enter the timing you found in subsync. Should be ok then.
Subtitles problem !
By mathbes in forum Blu-ray RippingReplies: 1Last Post: 17th Sep 2011, 16:39 -
Another Subtitles Problem
By Djanarak in forum Video ConversionReplies: 4Last Post: 5th Jun 2011, 05:30 -
Problem with subtitles
By romanvida in forum Authoring (DVD)Replies: 1Last Post: 4th Oct 2010, 14:38 -
greek subtitles problem
By ioakim in forum Video ConversionReplies: 1Last Post: 15th Aug 2010, 04:31 -
Problem with the subtitles
By empana in forum SubtitleReplies: 2Last Post: 11th Nov 2008, 04:54
