Hi,
Just upgraded to a p3 700 (you can go see my specs,i think they are public)
I've reformatted and reinstalling everything , i do have the latest drivers for all of my components and Win 98se cannot be more updated that this.I only have one HUGE problem.
Everytime i try to open any video file (with their latest player of course) my computer freezes. Since my big update my computer has been doing fine ,that's the only problem that i have.
Any ideas
Thanks a bunch
use a different player... install a codec pack (see tools section to the left) for most recent codecs...otherwise...computer is just not stable.
Thanks TMC for the answer.
Actually what did the trick was to take out my video card out from the AGP slot and put it back in , restart and lower the graphic accelerator of windows to zero and restart again.
Everything's fine now ,thanks anyway -
If it won't run right with the accelerator set to full, soomething is wrong with the card, board, or drivers.
THX Optimiser for PC monitor
By smartel in forum Newbie / General discussionsReplies: 11Last Post: 26th Mar 2011, 13:56 -
the abyss THX menu
By tcguy444 in forum Newbie / General discussionsReplies: 2Last Post: 5th Feb 2010, 09:14 -
how to insert subtitles....thx from spain
By xaviereb in forum ffmpegX general discussionReplies: 1Last Post: 22nd Nov 2008, 09:57 -
How to connect my cable box to my computer~~? THX~~
By bl3311 in forum DVB / IPTVReplies: 2Last Post: 25th Mar 2008, 18:47 -
THX HD DVD Movies????
By ofield1 in forum Newbie / General discussionsReplies: 4Last Post: 20th Feb 2008, 19:45
