Okay I have read virtually ever singel help guide. I am more confused now then I was when I started a couple weeks ago.
I have downloaded almost every single file on the net relating to this hobby.
I basically need to know peoples opinion on the BEST guide to follow doing this:
Downloaded a Move off a public ftp used Winrar to extract the files.
This movie is Super Troopers which is an AVI.
Its extracted fine right now and ready to be encoded correct ?
So I open up TMPGencand encode the file
I am still cofused which bitrate I should use since I want to watch it on my dvd player at home and not my computer.
Anyways that is not really the point.......
After I encode the file then I am suppose to author it correct ?
I have the general idea on how to do this but what I am looking for is a direct link to the best guide to do this process.
I have read them all and not sure which isbetter suited for me.
Avi - DVDR disc -to play on my dvd player at home.
Any help would be greatly appreciated.
Yes I am a newbie !
I'd also like some help with this question as well. The last DivX movie I converted to SVCD using the default TMPGEnc options looked like a low grade VCD.
Well if its now an AVI, then yes. But I would check it for junk frames in Vdub first.This movie is Super Troopers which is an AVI.
You don’t need to change anything, just click the load button and choose PAL or NTSC VCD template, that set's everything up for you.I am still cofused which bitrate I should use since I want to watch it on my dvd player at home and not my computer.
Yes most of the popular Burning programs can also make VCDAfter I encode the file then I am suppose to author it correct ?
Usually this is located in the program under "help"I have the general idea on how to do this but what I am looking for is a direct link to the best guide to do this process.
crap in crap outI'd also like some help with this question as well. The last DivX movie I converted to SVCD using the default TMPGEnc options looked like a low grade VCD.
Except it wasn't crap in. I don't remember the exact specs from the movie, but it looked near DVD quality in its DivX form.
Manabyte, you can try the Kwag templates:
http://www.kvcd.net/dvd-models.htmlHello. -
Then did you load a SVCD template, or use something non standard.Originally Posted by manabyte
All the DVD rips I have seen converted to SVCD are just fine.
DVD to AVI/DVDR and AVI/WMV/MOV to DVDR
By BIFFtheSTIFF in forum MacReplies: 5Last Post: 19th Nov 2010, 13:35 -
Command line method to convert MPEG-2 to Divx Home Theater Profile
By CLIjunkie in forum Video ConversionReplies: 15Last Post: 6th May 2008, 22:22 -
Best conversion method for mass DVD to DivX
By spidey in forum Video ConversionReplies: 3Last Post: 1st May 2008, 09:29 -
What is the easiest method to add intro clip on DIVX ?
By rob3rtz in forum Newbie / General discussionsReplies: 3Last Post: 7th Oct 2007, 05:35 -
Best capture card and method for VHS to DiVX?
By Vantage in forum Capturing and VCRReplies: 9Last Post: 4th Aug 2007, 15:11
