I just reinstall tmpgenc 2.57.41.146
and i still got problem with it
when encode a avi to mpeg 2
the movie stutter shocks skips whatever you wann call it
doesnt matter what template i use
this avi file bitrate 23.97 iwanna encode it to pal 25
when its done it shock skips stutters
whe i leave on the same 23.97 its oke but then i cant author it
oke but that not the problem now
i wanna encode to pal
can some off you help me out
You need to convert the AVI file to PAL (25fps), or why not just keep it as NTSC? (unless you can't play NTSC of course)
USB AVCHD for ps3 doesnt work
By caner12 in forum Video ConversionReplies: 2Last Post: 10th Aug 2009, 16:28 -
Remove WGA 1.2 doesnt work
By jyeh74 in forum Newbie / General discussionsReplies: 5Last Post: 7th Mar 2009, 00:46 -
Conversion to FLV - ffmpegx doesnt work
By indianiec in forum Video ConversionReplies: 3Last Post: 17th Jan 2008, 01:36 -
Some audio doesnt work
By TheEmperor in forum AudioReplies: 2Last Post: 16th Aug 2007, 10:05 -
Member Status......doesnt work
By electricsguy in forum FeedbackReplies: 14Last Post: 25th Jun 2007, 11:21
