Hi
I have read some other posts but am not sure as to the answer.
I connect my capture card (averTv Studio) via the s-video input. At the VCR end is a scart adapter which has a composite, s-video, and left and right phono sockets.
Every now and then it switches to b&w which is highly annoying if i'm trying to record.
Any ideas???
I have read other posts with a simlar but not identical problem saying the video must support s-video. If it has a scart out surely it should. There is a composite in and phono sockets on the front of the video too.
Most people complaining of this problem dont seem to be able to get any colour. I can but it switches at various times. especially if i play a video.
Cheers
Fozz
Hi
I put the scart in the back of the tv. The problem is still there. Could a faulty scart be the issue?
Is it possible for faulty scart to switch to b&w??
Bit of a shot in the dark as i'm no techy.
It is a gold plated scart tho and gold plated s-video lead.
Cheers
Fozz -
Hi
After some further moving of wiring etc........
I now have my s-video lead going straight into my cable box via the scart adapter. Slighltly better picture than before, no b&w. Almost perfect on some channels but.....
I now can't capture from the VCR. If s-video wont work properly thru the video would composite work via a scart adapter?? Co-ax is very noisy.
Cheers
Fozz -
Well it seems I was wrong I just got black and white again......
Main suspect now is the scart adapter anyone disagree with that?
Fozz -
A Scart socket on your VCR doesn't necessarily mean that it can output S-Video. However the fact that you can sometimes get colour suggests that it can.
S-Video passes video signals through two pins - chroma and luma. If one of the pins or wires were faulty then you could indeed see a black and white picture. Does the picture change as you wiggle the cable? If so, you definately have a faulty cable or socket.
A Scart plug can carry RGB, SVideo and Composite video signals. You will probably have to configure your video to output the correct signal though. I use a Scart to Composite Video & Stereo Audio cable to perform my capturing at home. I am more than satisfied with the quality I get from the composite source. -
Cheers for that. I think it was semi-compatible. I have now linked up via composite and the picture is better than ever.
Cheers
Fozz
VHS-C playback issue, playback in B&W and distorted/noisy colour.
By jpoel in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2010, 10:36 -
Unknown video colour noise / interference issue ... driving me mad!!!
By yakpith in forum Capturing and VCRReplies: 0Last Post: 30th Jul 2010, 07:59 -
Changing Night Mode Cam Video to Normal Colour or B/W
By Mr Baldman in forum RestorationReplies: 2Last Post: 3rd Jan 2009, 05:06 -
Problems with screen blank using component video switches
By digitalsamurai in forum Newbie / General discussionsReplies: 0Last Post: 27th Feb 2008, 17:51 -
Deep Colour/xvYCC colour/x.v.colour confused consumer
By ArthurDaley in forum DVB / IPTVReplies: 10Last Post: 9th May 2007, 19:10
