Synthom: after creation, a motion menu always looks like a still one with nothing visible inside the chapter frames (they only look like dark boxes).
This happens both with the TSCV "Preview (S)VCD" function and on a standalone DVD player.
I think I now found the reason of the synthoms I see:
the motion menues I generate, although looking like still ones, are indeed composed by a sequence of images; HOWEVER, each frame stored in the "\seq" folder shows the menu screen layout with all the background and title visible, but with the chapter "frames" ALWAYS DARK, no matter which seq_nnnn file I try to visualize.
Has anyone ideas on how to eliminate this inconvenient?
Thanks.
OK, im now also having the exact same problem. Does anybody know how to fix it?
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 14:08 -
stills to video speeding up frames/sec or stop motion
By slnorth in forum Newbie / General discussionsReplies: 3Last Post: 10th Oct 2010, 23:06 -
batch detect and delete black frames
By boshreek in forum EditingReplies: 0Last Post: 25th Mar 2010, 16:47 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 12:01
