OK Guys Weird Question coming up. I downloaded a movie in divx.avi format and it works great on a divx player or even my Windows Media Player, because i applied the neccessary patches. But when i use tmpgenc to encode it to vcd format, it doesnt encode any video at all just sound. It's Like its no there or just i had something set wrong. So idecided to use crappy nero to encde it and what do ya know same thing- no video!! Well, looks like i have to leave this up to you guysSo anything you can help on would be great!
if u are encodeing to mpeg layer 2 (ie svcd) then u will only hear the audio. u need to download and install a dvd viewing program, i use power dvd. it is in the tools section
if u are not encoding to mpeg layer 2 then i cant help ya, sorry
Death, is only the begining -- Imhotep -
TMPGEncOriginally Posted by lilmarkie
Select options > environmental settings
click the VFAPI plug-in tab
right click the "DirectShow" and select higher priority, do this several times until its at the top with a value of 4
But first Install the Nimo codec pack.
http://nimo.everwicked.com/ http://perso.wanadoo.fr/nimo/ -
ya, i had the same problem for a while, the nimo codec pack solves everyting
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
Can't convert avi to an avi that the my divx player will read.
By aarelovich in forum Video ConversionReplies: 5Last Post: 4th Feb 2010, 06:19 -
divx to avi with divx author
By pred in forum Video ConversionReplies: 4Last Post: 12th Nov 2008, 23:32 -
avi to DivX using divX converter pro
By Deaf Raiders in forum Video ConversionReplies: 3Last Post: 19th Dec 2007, 13:28 -
Convert this avi to DivX avi (GSpot Screenshot included)
By indiannawaf in forum Newbie / General discussionsReplies: 13Last Post: 22nd Aug 2007, 11:26
