  1. I heard somewhere that certain models of CD RW Drives with firmware and laser diode change cn be made into a DVD Writer
    Has anyone any info on this?
    Thanx in advance
    Jul 2001
    Maryland
    where are you gonna get the new 650mm laser diode and the drive hopper.
    If it's external, you gotta redo the USB-IDE translator bus.
    Why not just buy a DVD-RW, I saw them for 249.95
    Mar 2001
    So. Calif.
    I hope you are a firmware engineer too. Habla x86 assembly?
    Oct 2000
    I have a similar question:
    Is there any way to modify a 1973 VW Beetle into a 2001 Porche Turbo?
    Will I have to change gas grades after doing this?
    Thanks.
    I don't have a bad attitude...
    Life has a bad attitude!
  5. a 1973 beetle would be an invention indeed..
    Can be made into a porche though... Get a totall loss casco from the dump and repair usingn spareparts from other porches... Use evert boult that's fits from the beetle...and here you go...
    For the serious part...
    You can convert a CD-RW into a DVD RW as well as a CDROM player into a CD Recorder...You would have to replace the whole thing...
    So Forget it.
    Oct 2000
    "You would have to replace the whole thing... "
    Hmm...
    If I didn't know better, I'd say that was the point I was trying to make!
  7. Sure it was..
    But just in case Mortechsystems didn't catch it the first time...
    Greetz.
