For the last week I have been trying to convert a DivX .avi file to SVCD for playback on my DVD player. I'm new to all this by the way!!!
Have been using TMPGEnc using just about every different setting, but the final .mpeg is always out of sync. So I then tried Virtual Dub, to get a seperate .wav file.
Anyway, still having sync problems and now attempting the "Fix Audio Drift etc" way of doing it, although not very hopeful.
The frame rate of the film is 29.97fps (its actually "Chasing Amy - DVD
Rip", and the strange thing is, is that sometime when I play it back (on Realplayer) the finished .mpeg file is in sync, and then seconds later the same file is out of sync, in exactly the same spot! Also if I watch it through, the beginning is in sync, and then a few minutes on in the film its totally out of sync.
I have tried putting it on to SVCD using Nero and created a nice menu, etc, and when it played, the film was tiny, and was in the top left of the screen rather than the normal way it should be viewed!!!
Argghhh!!!! Please, please please, someone help me! Need advice desperately as my g/f is getting annoyed at how much time I'm spending on the PC trying to do this!!! I'm desperate so I thank anyone in advance!!
Thanks!!!
UPDATE:-
Gave up doing the "Fix audio etc" as it was going to create a file over 20gigs in size!!!
Also, the file is a DivX Codec 4.12 file, with a 512 x 224 screen size
I don't know if this will make much difference or not, but it's something you should do even if it doesn't necessarily help you this problem. try installing the Nemo codec pack on the tools page.
Hi, thanks for the reply.
Tried installing the pack earlier, but think I have sussed it out anyway. I have tried a different DivX film, and managed to finally get the settings right so that its all in sync (apart from the original film being corrupt about half way through! lol) So, I'm getting there slowly, just need to find somewhere better for getting DivX films from!!! Kazaa is just too damn slow!!!
Thanks again
Encore CS4 DVD Image Build is incredibly slow
By aple in forum Authoring (DVD)Replies: 1Last Post: 22nd Jul 2011, 11:42 -
DVD ripping incredibly slow
By moults in forum DVD & Blu-ray WritersReplies: 12Last Post: 18th Jul 2010, 16:31 -
Frustrated trying to burn SVCD
By InfoSeek in forum Newbie / General discussionsReplies: 15Last Post: 8th Mar 2010, 21:34 -
why are my MOV file so incredibly huge?
By Bansaw in forum Newbie / General discussionsReplies: 4Last Post: 20th Sep 2007, 11:44 -
Dreamhost incredibly slow.. thinking of switching to a new host - which one
By Garibaldi in forum ComputerReplies: 0Last Post: 17th May 2007, 16:59
