  1. I'm having trouble converting smr avi's to mpegs. I have installed the smr patch and I use TMPGEnc Plus v2.5. It showed that it converted. When I ran it to view I had small blocks of color in about 1/3 of the screen. What can I do to fix that or is there a better program to use ...thanks
  2. Banned
    Jun 2001
    UK
    You don’t need the SMR (Angel portion) to convert SMR group AVI's, get it uninstalled, that is the problem with your colour.
    Install only the Nimo codec pack, and if necessary DivX 5.02
