Hi all,
I've been using Vegas Video 3.0 the last couple of days to try to cap vhs video to burn to VCD. The video I want to capture is about 45 minutes long. So far, I get about 10 minutes into the video and it quits capturing due to the 4 GB limit. It is recording into an umcompressed .avi format I guess. At first I was using huffyuv then I tried a couple of other ones including the mjpeg format and a different yuv format. Every time it quit about 10 minutes in. I want to record into .avi because as I have read, it is the best quality format, but it seems like there would be some way to get mor than 10 minutes out of it. What kind of compressed codec should I use? I am using WinME. I would really appreciate some help because this is driving me batty!!!
Thanks...
Maybe this table can help you decide:
http://www.vcdhelp.com/vcd.htm#compHello. -
http://www.vcdhelp.com/faq.htm#spillsystem
This is how you bypass the 4gb minimum problem. -
This is another way to beat the 4GB file-size cap:
http://www.tccomputers.com/apps/products/ppp.php?product_id=MSXPCDHOMEAs Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
avi files can only play up to 40 minutes in DVD player, why?
By ericdunn in forum Newbie / General discussionsReplies: 8Last Post: 7th Apr 2010, 09:37 -
Divx player no longer finding recorder,need other avi burner
By wallflower22 in forum Authoring (DVD)Replies: 2Last Post: 19th Apr 2009, 15:50 -
Sounds stops capturing after ~7 minutes every time
By rmcc4444 in forum Capturing and VCRReplies: 5Last Post: 13th Apr 2009, 13:18 -
Question how to edit several minutes of avi at frame level
By jimdagys in forum EditingReplies: 9Last Post: 23rd Dec 2008, 19:26 -
Video Sharing Site longer than 20 minutes
By xeroid in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2008, 18:03
