I have been using Winmx and Kazaa to d/l files so far, but I decided to switch to kazaa lite and see what all the hype was about. So I removed kazaa, ran adware, removed all the suspecious files and reg., d/l kazaa lite, installed it, tried to run it and it won't connect to the site! What is wrong with it and how can this be fixed?
Did you get the latest ? 1.72 ?
When you run adware now, don't delete the cydoor (fake) -
When you ran adaware there was one file that you removed that shouldn't have been removed.
cd_clint.dll
This is a dummy file that does nothing and it is what replaced the spyware file in Kazaa.
How does KaZaA Lite get around Spyware?
It gets around it, quite simply, by not installing it!
Both the Original KaZaA and KaZaA Lite (because KaZaA Lite has to work exactly the same as the Original KaZaA) actually check for CyDoor on your machine and will not run without it. However, KaZaA Lite gets around this by installing a dummy version of CyDoor, which appears correct to KaZaA, but does not serve the adverts, meaning they don't appear in KL. It also stops random pop-ups from appearing while you're using KL. This dummy version of CyDoor is from a group called Counterexploitation (CEXX).
Then reinstall kazaalite and leave it alone.
Or make sure that Adaware is not set to automatically delete found files and put this file in the exeptions list.
This dummy file is needed or the program won't work.
Hope this helps.
Want to use K-Lite? - DON'T DO IT!
By jeanpave in forum Software PlayingReplies: 45Last Post: 15th Nov 2010, 22:04 -
New Lite-on drive being recognized as old lite-on drive
By tlrbjc in forum DVD & Blu-ray WritersReplies: 2Last Post: 23rd Jun 2010, 08:21 -
LITE-ON LH-20A1H Problem
By mn072065 in forum DVD & Blu-ray WritersReplies: 11Last Post: 12th Jul 2008, 13:02 -
Has anyone used Lite-on EZ-Dub
By Ronny G in forum DVD & Blu-ray WritersReplies: 11Last Post: 1st Feb 2008, 01:34 -
nintendo ds lite
By Mr anderson in forum Off topicReplies: 5Last Post: 19th Sep 2007, 01:02
