  1. When i trie to import a movie from TmD into TMPGEnc i get an error that this file is unsupported or can not open. With nero i can convert it to VCD but i think that there must be a better .What is it that i m doing wrong
    Dec 2001
    USA
    Options>Enviromental settings> vfapi plug in. Set Directshow multimedia File reader set priority to 4. Right click on directshow to increase priority
    May the force be with you.
  3. Banned
    Jun 2001
    UK
    Sounds like you have the codec missing, install the Nimo codec pack
    http://nimo.everwicked.com/ http://perso.wanadoo.fr/nimo/
    Also www.divx.com for divX 5.02
