Ive got a new Compaq Ipaq and have got a Divx player and a MPEG1 player which runs on the pocket pC
But the movie files are to large, it will only hold 64mb does any one have any sugestions on how to re-encode my Divx or VCD's to be smaller in file size.
Ive tried using TmpGEnc reducuing the size t0 160x120 lowering the bit rate and the audo but they are still to huge, and i cant find any where how to edit Divx files??
can any one HELP
regards
vcdmad@aol.com
Converting a 700mb divx to 64mb is possible, but the quality would so bad that it would be practically unwatchable....
Load into VdubOriginally Posted by vcdmad
Video > full processing mode
Video > compression > Select a codec > change bit rate for smaller size
Audio > full processing mode
Audio > compression > select codec > change bitrate for smaller size
Video > filter > Add > resize > adjust size
SAVE AVI
If you have any borders, add a crop filter first (Null transform) and remove them -
I'm going to do it...take the smallest movie I got ..Payback...709,776kb and try to getit down to 1/10 the size and see what it looks like...Just think, if its good...I can fit 10 movies on each VCD...
yea..right
Can I make a AVI file smaller?
By baebbe in forum Newbie / General discussionsReplies: 7Last Post: 15th Aug 2008, 15:04 -
How do I make a AVI Smaller?
By gottiman in forum Newbie / General discussionsReplies: 2Last Post: 2nd Dec 2007, 04:35 -
how do i make a file smaller?
By Sanosen in forum Newbie / General discussionsReplies: 5Last Post: 28th Sep 2007, 22:57 -
How to make an audio file smaller?
By aruwin in forum AudioReplies: 13Last Post: 29th Jun 2007, 22:01 -
Want to make 1GB ASF smaller
By jabroni in forum Newbie / General discussionsReplies: 2Last Post: 16th May 2007, 23:01
