  1. when encoding using TMPGenc a perfect avi file when changed to mpeg results in periodic colour distortion and blocky pictures.
    Is there anything Ishould do before starting encoding
  2. Banned
    Jun 2001
    UK
    Start by making sure you don't have the SMR (Angel portion) codec installed, if you do get rid of it. Install the Nimo codec pack.
    Then in TMPGEnc
    Select options > environmental settings
    click the VFAPI plug-in tab
    right click the "DirectShow" and select higher priority, do this several times until its at the top with a value of 4
    Before you start, click the load button and load a VCD template.
    Aug 2002
    Canada
    Just tried this but I also get the blocky pictures and color distortion .. any other ideas?
    Aug 2002
    Canada
    check the framerate in the avi first.. you may have one thats at like 20 fps. then open TMPenc and close the wizard.. click on browse and load up your movie, then click settings and you'll see the framerate, you can change it there.. this worked for me.
  5. Banned
    Jun 2001
    UK
    Have you scanned for junk frames in Vdub ?
    TMPGEnc
    Setting > Video > motion search precision "High quality Slow"
    Aug 2002
    Canada
    Its the framerate.. the original was 20 fps, it converted to mpg at 60 fps. This is the problem, so once I saw this I changed the framerate on the mpg conversion to 19.98 and volia it now works fine
  7. Banned
    Jun 2001
    UK
    Then why are you changing anything ?, once you load a VCD template there is nothing to change
    Aug 2002
    Canada
    If I didnt change the template (like I did orginally) the mpg comes out distorted and blocky colours appear on the mpg. This is what I said in my original post..
    So when I close the template and just change the frameratem the mpg comes out perfect. You NEED to change the framerate with this avi I had..
