    I used to make VCD rips of DVDs. This was the method I used:
    Smartripper -> DVD2AVI -> TMPGEnc -> VCDEasy
    In TMPGEnc, I would use the "source range" setting to split the d2v into two mpeg files.
    What I am wondering is this:
    Instead of using the other method for going from DVD to DVD-R, can I just go from the d2v and .wav from DVD2AVI to the DVD template in TMPGEnc and make one long file for DVD-R?
    (instead of doing the m2v/rempeg2 method I read abouit in the DVD to DVD-R faq)
    It seems intuitive, and I want to do it because I have never been able to do it the m2v way, there is always choppiness and audio synch problems.
    Andy
  2. Member spidey's Avatar
    Apr 2001
    U.S.A.
    I don't author DVDR's or encode to them, but I would say SURE. I only do SVCD's / VCD"s
    The only issue could be is what type of audio format does the DVD template encode to out of TMPG ? If it's the same as your other method, I'd see no problem. There's plenty of ways to do the same thing. Find what works best for you and enjoy
    ~~~Spidey~~~
    "Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
    i think it just makes an mpeg2 file. has anyone done this the way I described?
    Andy
    What I meant was, the mpeg2 file has the audio embedded (right?)
    Has anyone done ripping the way I described?
