I have a few questions. I can really use some help. My biggest
problem is I have a 600mgh PIII so I'm looking for a quick solution.
I use smart ripper and nero fine my questions are inbetween.
Is Flask better then xmpeg.
i have downloaded xmpeg 4.5 and it worked once now it
will not open vobs.
when it did work it was a full 3 fps quicker than flask expert xis
i have tried so many codecs and programs to encode I have erros in
the os I believe now. My machine will not shut down, it jsut keeps rebooting.
I am going to reinstall the os win 200 pro, but i just want to install one solution this time instead of screwing with everything else.
i must have 6 versions of flask on my machie, i got them here
http://www.digital-digest.com/dvd/downloads/flaskmpeg.html
that is also where i got xmpeg.
the last question is codecs, flask has bbmpeg allready installed
as well as a bunch of different profiles, vcd, svcd and so on.
i read that tmpeg and cinema craft are supperior but i can not figure out how to get them running. i put some kind of plug in for cce in the flask dir, and it has an error when it boots, it still does the encode and its 2ps faster than bbmpeg but no screen comes up for it like bbmpeg and nero says its noncompliant vcd file. so i keep going back to bbmpeg
the last problem is in xmpeg there are no plug ins for codecs just avi and i can not figure out how to get them for xmpeg.
i can really use some help thanks
Results 1 to 1 of 1
Newbie needing help downloading adobe video
By pistolpete1979 in forum Video Streaming DownloadingReplies: 4Last Post: 31st Aug 2010, 18:32 -
Newbie needing help converting MKV to AVI
By deadman36g in forum Video ConversionReplies: 12Last Post: 8th Aug 2010, 15:06 -
Newbie making good progress with 1080i content needing expert advise
By djdrock in forum Video ConversionReplies: 20Last Post: 27th Jun 2008, 12:01 -
needing codecs?
By 2mmy in forum Software PlayingReplies: 3Last Post: 22nd Mar 2008, 12:27 -
Needing a new Burner
By Burn it up in forum DVD & Blu-ray WritersReplies: 6Last Post: 21st Jul 2007, 23:52
