Hi
I created a movie for VCD. I cut the movie in 2 in order to have them 2 CDs. I then procced to burn the first CD. At the end of the movie I included 4 mores small files: 2 clips from the original movies and 2 more from my pesonal recordings. I did that to see if everything will play in secuence in de VCD. However the last to clips give warnings in the software I used to burn the CD.
I burn it anyway (since it allowed me). Now the CD is not recognized by the DVD players.
My questinon is: The fact that the two final files gave me warnings in the burning software can cause that all the VCD will be incompatible with DVD players???? The movie and the other two files had no problem.
Thx
Rey
Looks that way does it not
, run them through TMPGEnc and make them all VCD's Mpeg compliant
So, you are telling me that if you have 5 files in the VCD disk and just two (small) of them are not compatible (I am not sure they are not compatible since the software says that "they may not be" as a warning) all the VCD becomes a non-compatible for DVD players?
Rey -
It really depends on the VCD player. I have an Apex which reads just about anything, so there's a good chance your disc may play in another standalone player. If they don't, convert those small files with TMPGEnc first.
I have never added any non compliant files, if you get a warning that they "Might be" that's because it has found something wrong with them. Its telling you that not all DVD players will play non compliant mpeg's.Originally Posted by ranma_st
I would say that the authoring program has made a XVCD because of your none compliant files you added, your DVD player will not see it as a VCD
trailers and warnings tool to eliminate and end user friendly
By vanc in forum DVD RippingReplies: 20Last Post: 7th Nov 2010, 12:08 -
Test warnings
By alfresco in forum TestReplies: 3Last Post: 1st Feb 2010, 06:35 -
Eclipse report says 0 errors or warnings. . .
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 17th Jun 2008, 14:48 -
Are there any players/firmware hacks to allow skipping of warnings/preview?
By Sephiroth666 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 14th Mar 2008, 08:37 -
Laser printer warnings?
By Bartron in forum ComputerReplies: 8Last Post: 8th May 2007, 13:07
