hi
im trying to record an avi to a vhs videoplayer.
i connected my radeaon ve to the vhs- no problem the picture is good.
for the sound i used my minicd minjack2rca cable to connect my speaker jack on the soundcard to my L/R sound inputs on my vcr.
the problem is the sound is low and distant.
how to dub the sound good?
Results 1 to 9 of 9
Have you tried turning up the soundcard output volume through the icon in the System Tray?
go into control panel them multimedia then look for sound options
i mybe a noob but i know where that icon is.
i dont think the quality loss is becuz of that -
Do your PC speakers have a headphone socket? You might be able to boost the sound that way (as long as they are "active" that is).
Also make sure that the cable you are using is a stereo cable, some of the Y type of cables are mono but they split the sound into two channels.
Make sure that the sound card connector has two silver stripes on it not one.
HTH"Computers are stupid, but they are capable of being stupid one million times per second"
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 09:21 -
VHS to DVD to AVI
By rytter in forum Newbie / General discussionsReplies: 6Last Post: 25th Jul 2011, 18:49 -
VHS to DVD to .avi or VHS-.avi?
By xxnonamexx in forum Video ConversionReplies: 19Last Post: 30th Nov 2010, 16:14 -
Can someone help a newbie? Need the best device for VHS to AVI.
By basshurtz in forum Capturing and VCRReplies: 1Last Post: 28th Sep 2008, 09:43 -
What hardware do I need to go from VHS to Mpeg (or avi)?
By RichTJ99 in forum Newbie / General discussionsReplies: 8Last Post: 26th Oct 2007, 00:54
