  1. When I try to convert an asf file I have the audio does fine all the way throung, but the video only converts about halfway then just stops on one frame. Some have said it may be a a junk frame so I tried repairing it with vdub 1.3c. I think I did it right, but it still did not convert all the way. Any other suggestions? Is there another converting tool taht will take asf/wmv files that I can use? 8)
    Apr 2002
    The State of Frustration
    Try ASFTools
    Hello.
  3. I tried asftool as well adn it didnt work with the same problem.
