When I try to convert an asf file I have the audio does fine all the way throung, but the video only converts about halfway then just stops on one frame. Some have said it may be a a junk frame so I tried repairing it with vdub 1.3c. I think I did it right, but it still did not convert all the way. Any other suggestions? Is there another converting tool taht will take asf/wmv files that I can use?8)
if you left any junk frames, TMPGEnc will give trouble
Your using Vdub 1.3C ASF so that is the easiest, there are others like Graphedit, but more complicated to use.
Re-load the AVI that you thought you had removed all the junk frames from, and do another scan -
can you jsut tell me exactly how to do the scan jsut to make sure I did it right? Thanks
Ah !, one of those don't have the scan for junk frames.
There is a version of Vdub with ASF support "Vdub 1.4c ASF" but it also has scan for junk frames, it is on Kazaa
Video > scan video stream for errors
Video > direct stream copy
Audio > direct stream copy
SAVE AVI
This saves out a copy without the junk frames. You can do this anyway and sometimes it will fix more of the problems, even without the scan.
If you use TMPGEnc
you can also save out a AVI, don't know if that will also crash on the junk frames
File > output to file > AVI
ripbot only converts half the movie
By AmDD in forum DVD RippingReplies: 8Last Post: 11th Feb 2012, 06:50 -
RipBot converts only half the blu-ray movie.
By Obamargarine in forum Blu-ray RippingReplies: 6Last Post: 18th Feb 2009, 22:35 -
.MOD to AVI - video converts, but audio doesn't
By bball101 in forum ffmpegX general discussionReplies: 1Last Post: 3rd Sep 2008, 12:43 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 08:35 -
Uploaded video cut in half only top half shows
By MimseyTove in forum MacReplies: 1Last Post: 1st Jul 2007, 10:55
