Can anyone give me the tutorial of how to make subtitle with Sub Station Alpha? I can't seem to find the tutorials for that.
I only found how to apply sub in "Edit" section.
Well, I do not remember where I got the process from, but it is really simple. First load Virtual Dub (VDub) load your video and watch it with a pad and pencil.
When you get to spot where you want to put your first subtitle, stop VDub and write down the time and a mnemonic of your subtitle on your pad. Continue until you are finished watching your video.
Load Sub Station Alpha. In the white box without the numbers, type in your first subtitle. Then click in the top box marked "Start". Type in the time for your first subtitle. Click in the box marked "Duration", and load the amount of time you want your subtitle to last.
Sub Station Alpha will automatically update the "End" box. Press return until the next entry box highlights. Continue until all your subtitles and times are entered. Save the file as as an .ssa file.
Go back to VDub. Add the filter "subtitler" or "TextSub". Load the .ssa file into the subtitle filter requester. Frameserve or save the .avi file. You should now have subtitled video -- Voila!Hello. -
Thanks for the help.
But I got one more question, could u answer me? Okie, I wanna make a logo that appear on my video clipz. For example, you know like the TV channels, they have their logos on the screen. I also wanna make my own logo. Could u help me on that???
thanx in advance. -
The filter is called Logo. You have to create the logo yourself, using your favorite paint program. Then when you add the Logo filter, you select the file that has your logo. You can then use fade in/out, transparency, etc.
Hello.
SUB STATION ALPHA 4.08 - For 64 Bits Systems
By devilcoelhodog in forum SubtitleReplies: 6Last Post: 23rd Oct 2021, 13:51 -
Hardcoding Styled (Sub Station Alpha) Subtitles to Videos
By Eudorcas in forum Newbie / General discussionsReplies: 15Last Post: 11th May 2012, 05:57 -
How can I make alpha transparent AVI file
By MI6 in forum EditingReplies: 4Last Post: 2nd Nov 2011, 16:02 -
Sub Station Alpha will not install
By slobjones in forum SubtitleReplies: 2Last Post: 14th Apr 2009, 16:55 -
How to make 'alpha elements'
By terrypin in forum Newbie / General discussionsReplies: 3Last Post: 24th Feb 2009, 10:02
