    Jul 2002
    Malaysia
    what is the easiest way for me to remove or reduce hiss at vcd(.dat) file?
    Apr 2002
    The State of Frustration
    Did you make the vcd yourself?
    Hello.
    Jul 2002
    Malaysia
    viewcam to computer
  4. When you capture file, save video and audio streams separately. Download CoodEdit Pro, open audio file in it, use Transform > Noise Reduction. You can make a noise reduction profile by sampling a quiet part of the soundtrack (ie, only hiss), then apply the profile to the whole file, save, and encode your video and audio streams. Some editing programs, such as Vegas Video allow you to call the sound editing program from within the video editing program.
    Good luck,
    Alan
    Jul 2002
    Malaysia
    now I got a .dat file
    is that I must separate them with TMPGenc?
    which option should I know for audio?
    Audio?
    System(audio)
    System(video+audio)
