I have a few AVi(s) that have been created at 14.985fps. Is it possible to enhance the AVI to 23.976 fps? I need help and instructions.
One other thing. I want to convert from 14.985 fps to 23.976 fps to make the quality better.
You'll never improve the quality of an AVI by increasing the frame rate with existing footage. The old can't make a silk purse from a sow's ear principle.
You might change the frame rate to make a VCD or going from PAL to NTSC or visa versa etc. so it plays in a VCD/DVD player. There are frame rate guides for that.Panasonic DMR-ES45VS, keep those discs a burnin'
To synchronize 29,970 audio fps for 23.976 fps
By DruidCtba in forum Newbie / General discussionsReplies: 1Last Post: 27th Sep 2009, 13:01 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 16:23 -
Converting 23.976 fps to 29.97 fps
By wasimismail in forum Video ConversionReplies: 8Last Post: 14th May 2008, 19:26 -
Converting 23.976 fps to 29.9 fps
By zanos in forum Video ConversionReplies: 4Last Post: 13th Apr 2008, 10:03 -
Divx to NTSC DVD: is Dgpulldown needed if Fps is 23.976?
By kalii2 in forum Video ConversionReplies: 4Last Post: 20th Jan 2008, 09:29
