Is there any way I can quicken up the encoding using tmpgenc, It usualluy takes about 4 to 5 hours to convert one part of a two disk film, but for some reason I downloaded Snow Dogs yesterday and when I started to convert it, it said 4 hours estimated time, when I looked later it said 16 hours, at this rate it will be on the telly before I burn the bugger on disk. I'm only running a 500mhz cpu, is this the problem. Help please.
The CPU and other tasks your perform while converting may of course influence the speed. I have a 400mhz AMD processor... so i just fire up the convertion and go to bed or out for coffee
You could reduce your motion search precision setting in TMPGEnc but Cinema Craft Encoder is FAST FAST FAST (about 4 times faster than TMPGEnc given all else same eg. 2 pass). You can use this way:
http://forum.vcdhelp.com/userguides/78221.php
DVD2Svcd does the same thing to the video (if you choose CCE as encoder) but is far simpler. It takes a little extra time to process good quality audio but since it is an all in one package I don't have to nurse the program along.
right-click relatively slow
By alintatoc in forum ComputerReplies: 10Last Post: 3rd Apr 2010, 12:28 -
slow PC
By mac71671 in forum ComputerReplies: 4Last Post: 3rd Dec 2009, 22:16 -
Is Raid 1 always this slow?
By gary11364 in forum ComputerReplies: 7Last Post: 5th Aug 2008, 22:23 -
tmpgenc slow dvd authoring
By mystic818 in forum Authoring (DVD)Replies: 2Last Post: 20th Nov 2007, 06:21 -
Slow Mo
By josel in forum EditingReplies: 3Last Post: 13th Aug 2007, 03:43
