  1. when i encode a file in tmpeg the movie will be done at around 50% then the screen will just go blank
    If TMPGEnc says that the video length is way too long
    Try change the directshow reader priority, in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 and reopen the video. If that doesn't help you can always use the source range to select exact what to encode, under Settings->Advanced in tmpgenc.
    www.vcdhelp.com/tmpgenc.htm#problems
    it is probably because of that and changing the directshow reader often helps.
