Which settings are you guys using? Whats better for fast action with a lot of motion movies? Whats your best settings overall for fast action films?
I think you have a slight bit of confusion
NTSC is a standard for video used in Canada, the USA and Japan. PAL is a video standard used in Europe. A PAL VCR/stand alone/TV can't play NTSC disc and vice versa (ya ya I know...)
So use either NTSC or PAL based on where you live. For best quility there are a lot of things you can do:
up the bitrateencode with 2pass VBR (or CCE and 3-5pass)
encode SVCD IVTC to go from 30fps -> 24fps (ie. higer bitrate per frame)
etc. etc.
If you using a DVD source I'd get DVD2SVCD from http://www.doom9.org best (and easiest) program out there. It's a front end program that runs:
vStrip -> DVD2AVI -> tooLame -> CCE -> pulldown (NTSC) -> bbMPEG -> VCDImager
in theory just insert DVD, choose settings, and click ok. You'll get an image file ready to burn ov your SVCD/s.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
