I am trying to burn "the sum of all fears" which i have downloaded in a format i have never seen before "tcf-sofa". Another film worked fine, but this film when I double click on the Cue file once it has gone through WinRar, it comes up with the error "floating point division by zero", and only then gives the option to close down Fireburner. I have no idea why, so maybe someone can please help?? Thanks in advance!
Ok Nobody responded, but I found the answer after alot of searching. It appears that the issue is to do with Fireburner not liking something about the film, possibly a mathematical error, I used Nero and it worked fine! so instead of "fixing the error", more of a work around.....
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
Samsung R155 DVD Recorder - "Recorded" or "Blank"?
By mhamini in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Feb 2010, 19:01 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 05:45
