  1. I have a ASF = 8mb, I convert it with TMPG to MPG = 45mb
    whaaaaaaat!! thats huge, I had it on default setting ( MPEG-1 320x240 30fps CBR 1150kbps, Layer-2 44100Hz 192kbps )
    is there any way to make the size smaller without losing the quality of the movie??
    thanks 8)
    If you want to make standard VCD you must use that size, abuot 10 MB /min. If you only want it as a mpg lower the video and audio bitrate, check www.kvcd.net for some tmpgenc templates that uses lower bitrates without affect the quality that much.
