  1. Anonymous
    Guest
    i have dscaler and zoltrix program to watch tv how do i make dscaler to be the deffault player?
    cause when i capture tv with virdub it shows alwys zoltrix program's channel. i want to show dscaler;s channel cause zoltrix is not that clear as dscaler. also zoltrix doesnt detect all the channels
  2. Originally Posted by gongxia649
    Just go to "Settings/Video input" and select "Tuner" in Dscaler's menu.
    If you can't see the channels, go to "Hardware/Setup Hardware" in the menu, and verify that you have set your correct TV tuner in there.
    Then press "Alt+Enter" and you're full screen!
    -kwag
    KVCD.Net - Advanced Video Conversion
    http://www.kvcd.net
  3. Anonymous
    Guest
    i think u missundertaood the question
    my question is
    how to make dscaler default player?
  4. Originally Posted by gongxia649
    my question is
    Default player for what?
    Dscaler is not a player. It's a video processor, designed with it's own BT8x8 drivers, to process video from capture cards.
    -kwag
    http://www.kvcd.net
