Im looking for some kind of software ulity that can invert a video signal in realtime. I have a bt878 based tv card so it shuldn't be a issue with compatability. Any sugestions are appreciated.
Just incase your wondering, i need it to be reverted so i can watch my Optus Cable TV in australia as they invert there signal before it hits their decoder boxes, its a big hastle if you want to watch it using a tv card.
Do you actually mean "reverting"? If so, reverting to what previous condition or status?
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
yer i did mean reverting, i have fixed the problem now with dscaler, it works greats.
it said reverting because i wanted it to the polarity it was before optus(the cable tv provider) changed it.
Windows XP desktop keeps reverting to Default
By DarrellS in forum ComputerReplies: 11Last Post: 2nd Aug 2008, 09:39
