  1. Posted: Aug 15 20:34
    I can finally get to the last part in TMPGEnc and everthing works great ( I have a DVD burner and am trying to cconvert a AVI to MPG) but I keep getting a small window popping up that says ERROR and a number "57488376" I dont know what to do but feel I am close, can some one help please?
  2. Guest
    Sounds like you have an error in the avi at that specific frame? Not sure
    if that refers to frames or not but I have had the same problem. Take a
    look through the guides for checking your avi with Virtual Dub. It can
    basically fix any problem with avi's. Once that is done then run it through
    TMPGEnc. It should work.
    FYI: After the first run through VDub, run it through again. you may find
    more errors. Just making sure you double check it.
    M
