Hi there, I am new to this and have only recently begun ripping DVD's and capturing avi files through my TVcard. Is there a big difference in quality between SVCD and VCD. I've only come across VCD's and the quality of them is okay to watch, so is there a significant difference?
Will my PC take significantly longer to convert to SVCD format than VCD?
Thanks in advance!
chrome ;0)
Maybe you know this, maybe not but capturing the dvd loses an incredible amount of quality. If you were capturing straight to mpeg then it would at least be a much faster method, albeit lower quality. But since you are capturing to avi and then converting to mpeg your method probably takes even longer, and produces lower quality.
If your looking for a quick method of making vcds or svcds then capture straight to mpg, if your hardware supports it. Otherwise convert the vobs directly to vcd/svcd compliant mpgs. This is the preferred method since it produces the highest quality.
Now to your question. Yes assuming your source is high quality, there is a significant difference in quality. If you've ever seen S-VHS this is very similiar in quality to SVCD, while VHS looks much more like regular VHS. Also, if you do decide to capture the dvd, SVCD will support interlacing, whereas with VCD you will lose half or your fields, which basically means you are losing half of the movie's data.
As far as the encoding times...Mpeg2 does take longer to encode but not all that much longer really. However, SVCD supports VBR encoding which takes longer and you also may wish to use multipass VBR, which basically multiplies your encoding time with eacy pass, ex: 2 passes takes twice as long, 3 passes takes three times as long ect... -
Thank you for your clear explanation! Unfortunately my TVcard is old and can only record video as avi files and the audio as pcm files using Virtual Dub. I use TMPGenc to encode to Mpeg1 VCD PAL.
I use DVDx2.0 to rip DVD's that automatically converts to Mpeg1, so that's okay.
What I would like is a program like Virtual Dub that would allow me to record directly to Mpeg1/2 if possible, alternatively I'll have to buy a new TVcard I guess?
If you have any suggestions they would be most welcome!!
chrome ;0)
Does a Motherboard's Chipset Make a Difference?
By wulf109 in forum ComputerReplies: 1Last Post: 20th Oct 2011, 11:43 -
Gangsters and Jedis: First youtube video does 480p make a difference?
By AceTriggerMedia in forum Video Streaming DownloadingReplies: 5Last Post: 18th May 2011, 10:47 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 20:40 -
Does 4K really make a difference? Sony compares SD to 2K to 4K in PDF.
By edDV in forum Media Center PC / MediaCentersReplies: 3Last Post: 28th Dec 2008, 20:21 -
Does SATA make big difference for DVD burner?
By sdsumike619 in forum ComputerReplies: 6Last Post: 28th Nov 2008, 20:21
