I have a few VCD's that i would like to make copies of.
Is there a special way of doing this, using Nero?![]()
Just use the disc copy method. Little icon with 2 discs next to each other.
Craig -
Sometimes if you get problems with this you can make a CD image file on your hard drive and then burn the image
Big_Jit -
I just copied one of my multimenu VCDs with Nero the other day. The CD Copy function works fine copying from one drive (like a CD, DVD, or CDRW) to a CD-R(W).
If you only have one drive or a slow drive then yes make a disc image then swap in a blank and burn the image.Panasonic DMR-ES45VS, keep those discs a burnin'
Question : Why i can't copy from Protect VCD
By indianguy077 in forum Authoring (VCD/SVCD)Replies: 23Last Post: 24th Mar 2009, 06:42 -
Can I copy an original DVD to VCD?
By cxgcxg in forum Newbie / General discussionsReplies: 4Last Post: 31st Mar 2008, 04:50 -
how to copy the contents from a scratched vcd
By sumeshkri in forum Authoring (VCD/SVCD)Replies: 36Last Post: 28th Dec 2007, 02:03 -
copy contents from vcd
By sumeshkri in forum Authoring (VCD/SVCD)Replies: 1Last Post: 18th Dec 2007, 00:34 -
Making VCD Copy
By audiophile in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th Sep 2007, 07:20
