hi, i'm currently trying to create a vcd of my digital photo's using nero 5.5.9 but am getting so far in the burn when the eror message 'buffer underun appears. can anybody help? thanks![]()
I get this sometimes... Try burning at a lower speed 2-4x, restart your PC before burning and disable all non-essential background tasks...
What's a buffer under run ?, thought everyone had burn proof these days, however if there is a fault in the file, and Nero has to try and fix it, and fix it, and fix it
then no burn proof can help.
So always make sure you use mpeg NOT AVI and if its a capture using mpeg, make sure there are no dropped frames. -
if you lower than speed, it will be gone
eg. I have 12x rewrite, I get buffer underun ALOT so I switched to 8x now no error ( but slower though
)[/b]
ffmpeg gives buffer underflow
By zkab in forum Video ConversionReplies: 2Last Post: 9th Aug 2010, 04:45 -
YouTube Buffer Speed
By gooberguy in forum ComputerReplies: 4Last Post: 25th Feb 2010, 22:12 -
Help: ImgBurn Buffer Device @ 59%
By butt_crack in forum ComputerReplies: 2Last Post: 5th Feb 2010, 18:22 -
What is buffer size?
By dzsoul in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 10:04 -
Buffer overflow in tmpgenc?
By themaster1 in forum EditingReplies: 7Last Post: 15th Jun 2007, 17:08
