Ok, i followed the guide to the T about using M2-edit to cut and/or join clips.
When i generate, first it saves a TMP file thingy! Also, the file is like multiplied in size, like if i start with 20Mb of mpeg, i will end up with a 150Mb for the same length... help will be very appreciated in acheiving a well cut mpeg video with M2-edit.
Also, please don't tell me i can use TMPGenc or womble![]()
All you have to do is use Tmpgenc to demultiplex and then remultiplex the file, and it should come back to a respectable size. It has worked for me when I split SVCD's.
AVI files make DVD huge
By dishwater63 in forum Authoring (DVD)Replies: 6Last Post: 13th Dec 2010, 19:09 -
I need to edit a huge .avi file
By Hobittual in forum EditingReplies: 2Last Post: 25th May 2010, 15:40 -
DVD Shrink generates different files even with the same settings
By sldvd in forum Newbie / General discussionsReplies: 7Last Post: 20th May 2010, 17:19 -
DVD to FLV plus need to edit and file sizes are huge.
By mickthetree in forum Newbie / General discussionsReplies: 9Last Post: 6th Dec 2008, 10:07 -
Huge avi files in Virtual Mod
By KayAt in forum Newbie / General discussionsReplies: 3Last Post: 25th Oct 2007, 19:08
