I just bought a new tuner/capture card and tho the volume is working, i cant get it to go up. I have tried master volume, the volume in the prog, etc.
Help![]()
You need to adjust the volume under the recording settings of windows volume control.
Nick -
You have not updated your computer details, so we don't know what the card is, if its Mono, make sure the balance control is on the correct channelOriginally Posted by Akhet
Ok, I have the basic WIN TV 2000 PCI, also mono.
When I first got it, the audio recordings were low, I used www.goldwave.com for all audio work, and in the settings I did some checks. Eventually I moved the balance control to the left and the audio was then very loud.
Before it was very low
Even though I had left and right available going in on a stereo 3.5, it only listened to one channel.
PAL or NTSC camera : does it matter ?
By kirby7777 in forum Authoring (Blu-ray)Replies: 9Last Post: 14th Aug 2011, 14:51 -
Does size really matter?
By ingeborgdot in forum ComputerReplies: 21Last Post: 25th Jun 2011, 10:11 -
So is any DV codec better than MainConcept at decoding? Does it matter?
By Asterra in forum Video ConversionReplies: 11Last Post: 20th May 2011, 22:59 -
Can't get DivX to work with AutoGK no matter what I do.
By teapot in forum Video ConversionReplies: 4Last Post: 17th Jun 2010, 22:38 -
Sony trv 18 no internal speaker volume, no headphone volume
By websbymark in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 5th Oct 2009, 11:39
