Hello Everyone,
I know i am coming off totally retarted, but this is all knew to me. I am using Imesh to download movies. I saved the movie file onto my hard drive. Now the question is, How can I copy it to my DVD Writer or CD Writer ? I know I told ya all I am totally new to this. I have read on VCD and I am just not getting it. Is there somone out there that has the patience to help me out ? I greatly appreciate it. Thanks for all your help in advance.
Now you have to decide what kind of disk you wish to make.
If you want to make a VCD, you must make your file VCD compliant.
--If you have TMPGEnc, you load it there, select Load, select the VCD template, Ok, then start.
--Once this file is finished, you need a VCD burning software, like Nero, or if you like freeware, VCDEasy. You load it into one of these, insert your blank CD-R or CD-RW, and the end result should be a VCD you can play.
If you want to make a DVD, it is basically the same steps, except you use a DVD template, a DVD burning software, and a DVD writer. Any more questions so far?Hello. -
Tommy,
Thanks for the advice. I used TMPGEnc to encode the file and it works till i get to about 7% then the program stops responding. Now I am not sure if the file maybe be bad ? Please help ! This is getting frustrated ... -
Hang in there. Load the downloaded video into Virtual Dub. Select Video--> Scan video stream for errors, and let us know what happens.
Hello.
Lost Audio i think
By oz_surfer in forum AudioReplies: 2Last Post: 14th Jun 2010, 11:04 -
Lost Password
By HotDamn! in forum ComputerReplies: 5Last Post: 8th Jun 2010, 22:15 -
Lost Generation
By freebird73717 in forum Off topicReplies: 0Last Post: 7th Aug 2009, 10:35 -
Lost art
By Dv8ted2 in forum Off topicReplies: 3Last Post: 19th Apr 2009, 11:26 -
New to ffmpegX... Lost...
By Germaris in forum ffmpegX general discussionReplies: 3Last Post: 16th Apr 2009, 17:30
