I was just trying to learn how to use Partition Magic 7 and I partitioned my primary hard disk as 6 GB (C drive ) and another 6 GB(H drive).
Now I am trying to remove this partition and make it as 1 Primary partition 12 gb. How do I do that ?
PM7 has a wizard to merge partitions. It even leaves the content of the partition u want to get rid of inside a folder of your choice
I haven't used it for a while but if u need anything else just post it
Oh and good luck
I have tried that already . When I reboot my machine I got some error message. But still it has two partitions.
What was the error message ?
If I had to deal with that kind of situation i'd copy all I could to the partition i wanted to keep. after that I'd just right click and delete the unwanted partition.
If u don't have enough space on the partition u want to keep...well in that case I'd either use RW discs or copy and resize the partitions acordingly.
for now this is as far as my imagination goes, anyone else know a diferent solution ? -
There's always the hammer. I have a few, if anyone want to borrow them.
LOL the good old hammer. Hammer V2.0 ? Similar to our dear Hammering mechanism is fdisk that could be used instead of Partition Magic. I don't like it much but it does the trick. Someone else would have to explain the procedure 'coz i honestly dunno :/
Any other possible solutions ? -
I am getting this error message after I used partition magic.
1555 internal file number does not match position
my guess is something went wrong while you were creating the partitions. Merely resizing one of them might fix it (a long shot but a possibility)
Partition HDD
By videobread in forum ComputerReplies: 3Last Post: 16th Dec 2011, 11:22 -
Looking for free software to partition and backup netbook partition
By jimdagys in forum ComputerReplies: 4Last Post: 30th Nov 2011, 21:20 -
Norton Partion magic: schrink partition size ?
By themaster1 in forum ComputerReplies: 6Last Post: 7th Nov 2011, 16:53 -
Question about Disaster after using Partition Magic
By jimdagys in forum ComputerReplies: 9Last Post: 20th Nov 2009, 11:22 -
Partition Problem
By phodot in forum ComputerReplies: 3Last Post: 19th Nov 2008, 23:52
