Hello All...
What I'm going to do...
I want to get an RM file, specifically a Dragonball Z ep where Goku turns to Level 3, to a CVD at 352x480 NTSC or smaller.
Problem
When I use Trina to convert the RM to AVI file and open it up with virtual Dub and the sound is out of sync. I changed the interlace option and disabled it and on the sound sync option (this option is in the Audio Interlace) it changed the sound delay for 1100ms. It worked fine in one half of the video but then at another scene (when bulma and picolo are talking about trunks) the sound is WAY out of sync... like 2 to 3 seconds. Then it fixes itself and then it gets out of sync in different scenes.
Asking
So what can I do to fix this problem before i encode it to TMPGEnc.
The program i used to convert the RM file to AVI (note this RM file has been converted in perfect quality) was Trina. And it was encoded using Divx codec 4 and 5.
I have tried extracting the audio also.
specs. 128 RAM (note: PC was restarted before extraction to reset RAM)
1 Ghz, 7200 RPM HD.......
IF I double post then my internet explorer is going beserk...
Could you please use subjects that describes your post instead of just Help.
Use EO video instead of Tinra.
I've the same problem and with EO, look good.
http://www.eo-video.com
Good luck
