Is it possible to take an mpeg2 that has been ripped from a dvd and re-encode with tmpgnc to a smaller bitrate so it can fit onto a dvd-r? Is this a slow process and how does the picture look? Will the finished mpeg2 be accepted by authoring programs?
Thanks for the feedback.
By the way, I did try bbmpeg but it,s slow. Perhaps you guys know of another way of doing this while maintaing good quality.
yes it is possible, the quality will be great but it is a kinda slow process if you have a slow processsor. doom9 has guides for www.vcdhelp.com/dvdripping#dvd (the ifoedit guides)
Thanks for the info. I like the idea of using cce to do the encodes, but the guides you suggested do not explain how to get the mpeg2 into cce. I do not think it will accept an mpeg2 file, only avi.
Need To Batch Encode 78 MPEG2 Files
By hech54 in forum Video ConversionReplies: 7Last Post: 31st Dec 2010, 07:10 -
Does anyone got idea to encode VC-1 to Mpeg2?
By Dboyz in forum Newbie / General discussionsReplies: 2Last Post: 3rd Sep 2009, 08:07 -
Cut parts out of a mpeg2 without having to re-encode?
By ltd. in forum EditingReplies: 7Last Post: 23rd Dec 2008, 17:21 -
Better format to encode to: MPEG2 or DivX/AVI?
By Grunberg in forum Video ConversionReplies: 15Last Post: 15th Feb 2008, 08:29 -
I need to encode video to a 1280x720 mpeg2 at ~40mbit
By wldmn13 in forum Newbie / General discussionsReplies: 5Last Post: 18th May 2007, 16:19
