Hi
How do you tell if the file is a VCD file or a SVCD file.
The filename is: Bad.Company.SVCD.TS-Centropy.CD1.mpg
and the size is 788Mb
It says SVCD in the name, but it ends with mpg, isn't that VCD format?
Ok, SVCD in the file name is pretty much a give away that its a Svcd file. Both VCD and SVCD end in .mpg. If you want to check to make sure I believe you can open nero and do a standard compilation cd and just check what mpg format it has next to the file. MPEG-1 = VCD, MPEG-2= SVCD.
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
VCD o SVCD with extra data (installers)
By pmaril in forum Authoring (VCD/SVCD)Replies: 12Last Post: 17th May 2008, 18:17 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 11:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 21:25 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 11:27
